Being thrifty doesnt pay off long term
Very thorough. I bought mine with 3.5" thrifty lift (acutally height is 4") w 35's. The selling point to the bride was "it's all done....just a few mods here and there". In the first month I've replaced most parts, added more and more to do to get it right. Although I like the look of a taller lift and bigger tires, if i were to do it all over agian I'd prob opt for a smaller lift/tire combo.
Originally Posted by TheDirtman
(Post 3705652)
If you were to compare two Jeeps, one set up with a 4" short arm kit on 33" tires and one with a 2" lift and 37" tires with trimmed fenders the one on 37's, if properly geared, would run circles around the higher lifted Jeep. It would climb better, clear bigger rocks, be more stable in off camber situations, and would handle better on road due to the lower center of gravity. Both Jeeps would be the same height overall. |
bigger rubber closer to the ground
(Post 3706018)
Thanks Dirtman. I learned something new today.
damn good write up....if i had to get an actual kit i would install everything then measure the shock lengths i needed for my tire size and set up.
Originally Posted by Offroad
(Post 3706083)
But aren't the axles closer to the ground with 33s?
Originally Posted by Maertz
(Post 3706168)
yes but you are changing way more suspension geometry pushing the axles down more than just raising it all via tires.. Also you axle will be higher off the ground for clearance.
What about a body lift to raise the fender flares to fit the larger tyres and allow for stock flex?
Good writeup. Thanks for posting!
| All times are GMT -8. The time now is 03:02 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
