Need help with Electronic Disconnect install
I installed this on my X, its a straight up, unbolt, rebolt your new disco. 4 bolts for the sway bar, and two bolts on the links.
Did you get instructions with the harness? I took pictures for a write up, but have yet to do one yet. If you need them. I'll get the online tonight.
The wiring is simple, but the mopar directions, make it confusing...when its really not.,
I don't remember, did you use all stock wiring and switches? Did you need to have a re-flash for this to work?
I remember early on people were getting these things cheap, and when that caught on the price jumped. Wish I would have got in on that but I didn't have the Jeep yet.
The swaybar worked without having it flashed. However the light did'nt work. So I had it flashed.
I just got my rubicon 44 in the front, so I'm just going to pick up the harness, since I already of the locker switch.
Sure wish I could help install this. Too bad I'm gonna be busy.......doing..........something............els e.
Not to highjack, but I'd also scored a sway bar assembly recently, it only came with a pigtail though. I'm going to get the real factory switch panel and harness, anticipating being able to hang Rubi axles one day...
So I'd also like to see some pics so I know how to run the harness.
Speaking of, does anyone know the part number for the harness. I've found the switch panel from several places, but haven't found the harness. Just want to make sure I'm getting the right thing. Guess I'll email 4wdh, but it's Sunday.
Cheers.
Cheers.
Mopar has the instructions as a PDF file on their site if that helps any. It walks you through the instal and wiring......or you could just buy a new Wrangler with it installed at the factory
Why does the switch not work with the e-lockers? I just put on the wiring harness and sway bar, just waiting for my switch to arrive. I plan to put rubi axels under later.
He means that the factory switch only works with the Rubicon e-lockers because the whole system is computer controlled. You can't (easily) wire the factory switch yourself to control an aftermarket locker system.
Wait, what I meant to say was that Clackey is so skilled at working on jeeps. At least that what he tells me.
