Need Help With Extended Swaybar Links
Old Oct 24, 2011 | 06:11 AM
blackpanther's Avatar
Default Need Help With Extended Swaybar Links
Can someone advise me on what to get or do?
I presently have an OME light duty 2" lift I need to get longer links,but here is my dilema.
I have aftermarket 4.5" wheels that I use for the summer months,so that will not be a problem. What can I get that will work with the original Sahara wheels for winter without rubbing.
I also have an chance to buy some used wheels that have 5 1/8 backspace would that be enough.I am really stuck with this any help would be appreciated.
Old Oct 25, 2011 | 02:41 AM
BUMP?????????anyone
Old Oct 25, 2011 | 02:47 AM
ChryslerChris's Avatar
Get the 0-2 inch lift JKS quicker disconnects. They are adjustable to be just the right length. Can't tell if you're running a Rubi (I'm on my iPhone) but if you're not, you'll need these discos should you decide to go wheeling.
Old Oct 25, 2011 | 09:28 AM
aermotor's Avatar
Yep, get the JKS adj. Disconnects and adjust as necessary.
Old Oct 25, 2011 | 04:23 PM
Originally Posted by TheDirtman
Your sway bar will not change with the change in tires so adding the JKS quickers would be a good choice. Your axle will stay in the same place no mater what size tires you have.
My problem is not the tires it is the stock wheels.
I would love to get the JKS quickers but I have been told that extended links will rub on stock wheels.
Is anybody running extended links with stock wheels and no spacers?
