Need a little Procal advise
Old May 29, 2009 | 04:00 PM
pingtime's Avatar
Default Need a little Procal advise
Got my procal today and I set it for my new tires. they meaure 34" even and I set the Module and the horn wouldn't honk. I reset it for 34.25" and it took. went for a test drive and the sway bar light a check engine light where on and also the speedometer stopped working. I ran the DTC code and the check engine light went out. I ran the sway bar code for off and it went out but the speedometer still did not work. I set the restor and every thing returned to normal. I started all over again and same thing. any one have any idea why the speedometer stops working?
Old May 29, 2009 | 04:12 PM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
look here ,lots of info and some that sounds like your problem on around page 15 i think.
hope that helps.
https://www.jk-forum.com/forums/show...ghlight=procal
Old May 29, 2009 | 04:30 PM
pingtime's Avatar
Hey thanks. just what I needed. just did it again and now evey thing is working. with the shift points adjusted its more evedent than ever that I need to regrear.
Old May 29, 2009 | 04:52 PM
nangulator's Avatar
I had no problems with mine at all, wish I could help.
Old May 29, 2009 | 06:15 PM
fish's Avatar
right on man,glad i could help
Old May 30, 2009 | 02:02 AM
zook's Avatar
Mine did the same thing (no speedo) I just tryed it again and it worked.
Old May 30, 2009 | 07:25 AM
pingtime's Avatar
Every thing working. jeep shifts much less. even back up to 18mpg. I wasn't expecting that. can't wait for the gears.
