negative camber
Old Aug 18, 2013 | 12:51 PM
mrornge's Avatar
Default negative camber
I have a2012 JKU 37" 4"lift and I noticed my driver side front is at negative camber should I replace ball joints, or get alignment done
Old Aug 18, 2013 | 01:25 PM
mpkelley20's Avatar
How bad is it? did you gusset your front axle? Depending on how bad, you may have bent C's. Running 37's without reinforcing your axle is bad idea!
Nothing you can align as camber is not adjustable (unless you get adjustable ball joints). Post up your actual numbers so we can see how bad it looks.
Old Aug 19, 2013 | 05:16 AM
familytime's Avatar
JK Forum Regional Rep
x2 if your C's don't have gussets they will bend.Ball joints will help and you can correct the neg camber only if the C's are not bent
Old Aug 20, 2013 | 06:57 PM
mrornge's Avatar
I'm sorry guys I'm not following what Cs that might be bent. I took it to the shop and the only time he noticed negative camber was when the wheels were turned I never noticed that
Old Aug 20, 2013 | 06:58 PM
mrornge's Avatar
Wheels strait
Turned left
Old Aug 20, 2013 | 07:05 PM
nthinuf's Avatar
Originally Posted by mrornge
Just the angle of the pic, or is that a ton of Toe Out?
Take it in for a free/cheap alignment check and post the numbers. If the C's are bent, add gussets to keep them from bending further. If the axle itself is bent, it's decision time.
Old Aug 20, 2013 | 07:18 PM
Ghost63's Avatar
"C"s are the outter portion of the axle tubes where the ball joints are located. Named that way because when viewed from the front they look like the letter C. Running larger/heavier wheels and tires will increase the load in this area and can cause the C's to bend which will put your alignment off. Gussets are available pre-made, just a little welding required.
Old Aug 20, 2013 | 07:28 PM
Sgt Mack's Avatar
Looking at the tread wear and picture, is say its toed out.
Old Aug 20, 2013 | 07:34 PM
Ghost63's Avatar
Can't decide if that is uneven wear, or just the non-symetrical lug pattern on the tires. If it is toe-out, then the OP should notice the Jeep wanting to wander a bit in the steering.
