New axles and transfer case. Not sure what to look for. Any advice?
I was pretty much in the same boat as you. 2012 2-door planning to stay with 37" or 38" tires. I wanted the strongest axles I could get, that I could use as a DD without adding a shit-ton of weight, and not break the bank having to do it. I went with a PR44u up front and went with a semi-float XD60 for the rear.
I thank the good Lord up top that the cost out of pocket for the PR44u was very minimal. You have a good opportunity to pick up tgoss' PR44u for less (assuming price of shipping makes sense) and you could upgrade to the rear axle with the Super 60 ring gear, stronger carrier & ring bearings, stronger tubes, yet lighter package for the rear if you get the XD60. I can't remember the pricing off the top of my head but seeing you wouldn't have to worry about paying CA sales tax, you could get a tricked out rear SF XD60 for ~ $4800-$5200.
The XD is absolute beef whether it's full-float or semi-float. I opted to get it with the thicker extended length tubes which are still lighter and also stronger than the regular PR60. I went with 4.88 as well.
** edit **
Also if you stick with a 44 up front, you could essentially still use your stock front DS for the time being assuming you kept the stock (or Rubi) transfer case.
** edit **
I thought, however, that the Atlas uses solid gearing to drive the front drive shaft. The Rubicon uses a chain which is not as strong and can stretch. I could have sworn I saw something about that on an episode of Extreme 4x4.
Former Vendor
Lots of great info on this thread. Sounds like you were in the same situation we were in right before Moab on our 2 door that we built up. Not to throw another brand at you, but we ended up going with the TF44 for our front replacement. In my opinion (for what its worth), a built 44 in the front is more than strong enough for level 6/7 trails on a 2 door with 37s. You will save $ and weight. We ran Toyo 37s all over Moab during EJS and it performed perfectly.
We ended up going with the following:
Teraflex 44 with 1/2" walls and 4" caster correction
Ten Factory chromoly shafts (built specifically for my application)
4.88s
ARB front and rear
Adams Driveshafts
We were between Dynatrac and Teraflex. I am a huge fan of the ProRock and the TF44, but we were doing our build in a hurry and needed the axle ASAP.
Good luck!
4.88s
ARB front and rear
Adams Driveshafts
Good luck!
We are huge fans of Advance Adapters, and we're a distributor. We recommend them for a certain type of customer who doesn't mind getting away from the ease of the OE setup. Often times the cases are very hard to shift until they're broken in, and since they're a big, complicated aftermarket part, they come with aftermarket issues just like everything else. If you're down for that sort of thing then the ability to customize your gearing and the control of the super low gears is epic, but you want to make sure to talk to an expert and do your research before jumping in headlong into this sort of thing.
The Rubi case is chain driven but its no slouch by any means. I have beaten on my Rubi for years with only one transfer case related issue. I broke the stupid plastic clip that connects the shifter to the case. It is a very reliable case.
Sponsoring Manufacturer
We have had an incredibly busy year so far -- seems a lot of people want the best axles in the business! -- which created some long lead times. But those lead times are starting to shorten now. And the lead time is much shorter for a ProRock 44 housing that doesn't need a locker or gears setup.
Black Dog Offroad -- Thanks for considering our axle for your build. In the interest of stemming fake news, we want to clarify that our ProRock 44 axle housings for JKs are stock width and accept stock length axleshafts. The only time the shaft would be different is if a customer ordered a ProRock 44 that uses a conventional locker instead of the Rubicon locker, and we offer US-made high-strength 4340 chromoly 30-spline shaft kits that include 1350 U-joints for these applications. The reasons these are different is that the center pin in a Rubicon locker is slightly offset compared to a conventional locker, but the ProRock 44 housing is still stock width. Hope this clarification helps!
Ten Factory chromoly shafts (built for the prorock and the TF44 since they are slightly wider than a dana44)
4.88s
ARB front and rear
Adams Driveshafts
Good luck!
4.88s
ARB front and rear
Adams Driveshafts
Good luck!
Former Vendor
Thanks all for the help that you have given me. I am going to a local garage tomorrow to inquire about the work. I will also call two other garages to discuss the change and pricing and what not. I am excited to learn more about this.
I am pretty much sold on the Atlas 2 speed. I like what it can do. I am sure the Rubicon transfer case is good, but I like the what Atlas has to offer.
I will post when I know more.
-John
-John
