New Hypertech features available
Old Feb 9, 2012 | 08:03 PM
b5rider's Avatar
Default New Hypertech features available
I just installed the upgrades for the Hypertech tuner 52001. I had installed the previous tune and it made a small difference in the performance. I just installed the new upgrades which include throttle response, TPMS defeat, 4 different user selectable tunes that can be downloaded quickly, and on-the-fly ability to change the fan, idle, traction control, sway bar disconnect, and diff locker control (Rubicons) . I drove aroound and noticed a definite change in throttle response and my TPMS idiot light was not on. The speedometer is only off by 2 miles (per my GPS) and I can live with that. Once I change my gears I can quickly adjust the tune. The only mildly confusing part is setting the throttle sensitivity. It allows you to change the sensitivity from -50% to +50%. This is speed dependent from 0-10, 10-40, and 40+. I assume the negative values correspond to less sensitivity, and the positive to increased sensitivity, but it wasn't really conveyed. Overall, I am very pleased so far, and soon as I figure out the sensitivity percentages, I will make my throttle as sensitive as I can to reduce the lag of the drive-by-wire system. Hope this helps
Old Feb 9, 2012 | 08:16 PM
D_engel's Avatar
tpms defeat? I cant shut mine off completely. I have the new updates
Old Feb 9, 2012 | 08:35 PM
b5rider's Avatar
It's under one of the other menus. It gives you the option to turn it on/off. The menu you used lets you turn it down to 2psi. That menu can be accessed on the fly if you have the tuner plugged in while driving
Old Feb 10, 2012 | 07:28 AM
D_engel's Avatar
I discovered there have been software updates in the 3 weeks since I last updated my programmer. I downloaded the latest software and BAM, no more tire pressure light! Thanks for the tip
