new jeep/ new lift pulls left
I have a new jeep less than 5k miles on it and I had a 3" BDS lift installed with fox shocks and a adjustable front track bar and aev geometry brackets. And I now have a pull to the left. I took it back to the shop and they installed cam bolts on the lower control arms in opposite directions as the fix and now it has a very slight pull. I have read about the steering stabilizer issues and have ruled that out. I have read about thrust angle but don't think that is the issue since I'm using factory control arms. Any help would be greatly appreciated. I don't think the cam bolts are the answer pretty sure both sides should be in the same direction. Front axle is about 1/2 to the right. I'm going to start with centering that up and go from there. Thanks again.
That will bind the bushings up, causing a bit harsher ride. But I haven't seen anyone talk about it causing a pull to one side? (it certainly won't hurt to loosen all the bolts, shake it and bounce on the bumpers a few times, then torque them all again just to check it though.)
If the shop did an actual alignment, post the specs from the sheet. Sometimes people will adjust the caster a bit differently left and right for the crown in many roads. Maybe the Toe could be tweaked. There have also been quite a few people talking about a 'radial pull' in one direction from certain tires.
Did you put a new sterring stabilizer on? Like a Bilstein?
If your steering stabilizer has positive pressure on it, then it will make your vehicle pull to the left or right depending on which way it's mounted.
Didn't fully read OP. the cam bolts may be the problem, I had some similar problems with mine, although not as extreme. They may be slipping on the driver side a little causing your axle to pull in towards the rear giving you a slight pull.
Also, check your tire pressure, extreme differences in tire pressure can give you a pull, although it'd be pretty obvious looking at it.
I had the same lift installed and the guys at the shop said they would get it close but I had to go to an alignment shop to get it perfect. Just like they said, it pulled to one side, took it to an alignment shop that usually deals with lifted vehicles and they got it perfect.
They could have also moved your stabilizer so it was mounted at almost full extension and not providing any/very little positive pressure
If you have Nitto Trail Grapplers that may be the problem. Mine pulls to the left and have tried so much to fix the problem, but I after a lot of reading, it seems the Grapplers pull left.
