New rims and allignment issue?
I had the stock Rubicon BFG 32 inch tires mounted on new Black Rock 997 steel wheels. I noticed that the jeep is now pulling a bit to the right side. The rims replaced the stock Moabs and has 4.50 backspacing. The guy at the tire shop said that one mounted and balanced very easily, but the other four were about "average" as far as mounting. Has anybody ever encountered this before? Can an increase in the track width, or the increased lever on the bearing effect the alignment? I expected a rougher ride, but was surprised by the consistent pull.
Just took my tires off the stock rims and installed/balanced on new Black Rock 17's with a 4.5" backspacing and I had some problems getting the rims to get just the right amount of balance without having to weigh them down too much. I have not noticed any issues with the alignment though.
Originally Posted by GoodysGotaCuda
(Post 1769112)
Track width and rim width can change the characteristics of the drive. You are certain it's not following the crown of the road?
Is your Jeep lifted? If it is 3" or higher you need to check your caster.
Originally Posted by Rustler
(Post 1769235)
| All times are GMT -8. The time now is 03:24 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
