JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Noise "not use to ice in the south" (https://www.jk-forum.com/forums/modified-jk-tech-2/noise-not-use-ice-south-295457/)
ronixwrangler Jan 29, 2014 09:20 AM
we have been having some pretty serious ice here in Louisiana, ive noticed yesterday while driving my 11 2 door sahara that has rubi suspenion take offs on it that there is a cloaking noise coming from in the rear kind sounds like when a shock is bad and bottoms out, im not use to ice and everything being frozen, those that are use to the ice is this normal??
incubus2432 Jan 29, 2014 09:22 AM
I get some weird noises when it's brutal cold. If you have ice buildup on the suspension pieces it could add to the noise until it breaks up.
ronixwrangler Jan 29, 2014 09:28 AM
thanks, i was like holly hell i hope my wheel spacers arent wiggling off, thats what it sounded like lol
incubus2432 Jan 29, 2014 09:29 AM
If you are worried about the wheel spacers you better check them out. Can never be too safe.
SpicedCrusher Jan 29, 2014 09:31 AM
It's -30 with a couple of feet of snow where I am and I never get any noises. I would check to see if you have any ice build up that might be causing it as it's not normal.
ronixwrangler Jan 29, 2014 09:38 AM
thanks guys!
whitejeepjk Jan 29, 2014 12:45 PM
What you are likely hearing just ice built around some type of moving part, your jeep can handle it fine, mine as always been and we get bitter cold and ice and snow storms up north, your tires are likely harder and louder as well
Bonedoc Jan 29, 2014 12:51 PM
X2 here. My JK handles and rides very firm when it is cold but other than some creaking cold plastic in the cab it is quiet. My suspension makes no noise. Ice generally won't stay on moving parts to long as any vibrations and movement break it apart. The worst part is the ice that can build up around your fenderwell openings but even that is usually quiet.
whitejeepjk Jan 29, 2014 12:56 PM
Oh and just as a FYI, if you start to fishtail( when you slide and your @$$ end slides off center)turn towards slide not away or you will slide worse and do a 360.
ronixwrangler Jan 29, 2014 04:00 PM
Thanks everyone for all the info!!
© 2026 MH Sub I, LLC dba Internet Brands
