Odometer Discrepancy - Tire Size????
Old May 5, 2008 | 07:23 AM
TEEJ's Avatar
Talking
Originally Posted by bcperry2000
For X owners....keep in mind that you didn't start with 32s. i jumped from 29.3 inches to 34.8 which makes for a large difference
Here were my calculations:
Stock tire size - 225/75/16 - 29.3 diameter; 92.049 circumference
BFG tire size - 35/12.50/15 - 34.8 diameter; 109.327circumference
(109.327-92.049) / (92.049) = 18.77%
Then the easiest way to calculate your real mileage or real MPH is:
Mileage x 1.1877 = Actual Mileage
MPH x 1.1877 = Actual MPH
Actually - I STARTED with 32's on my X, and 3.73's....All I had to do was check off two boxes more, and bingo.
I just wish the 4.10 option was still there...they dropped it after the '07's
Old May 5, 2008 | 07:41 AM
neil17's Avatar
...and this just shows how much I need a refresher course in mathematics, haha.
Good info. If I upgraded to bigger tires I definitely would forget about the adjustments in MPG, distance traveled and the actual speed i'm travelling.
I may have to stick to stock for awhile
Old May 5, 2008 | 07:46 AM
bcperry2000's Avatar
you must have upgraded the tires then. the X base model comes with 225/75/16 tires.
Old May 5, 2008 | 07:58 AM
TEEJ's Avatar
Talking
That's correct sir. I also added dual tops, and other options.
S Package IIRC gave me the 255/75/17's, and some other stuff.
I clicked the $50 box to get 3.73's instead of 3.21 diffs.
Old May 5, 2008 | 02:19 PM
murray8144's Avatar
thanks for the help all - appreciate it!
Old May 5, 2008 | 08:08 PM
PAHUNTER21's Avatar
I went from the stock 32's to 305/70/16's - I've checked mine against 3 different GPS units and at 60mph on the speedo, it shows 60mph on the GPS. At 75, it shows 75... On all three GPS units (Garmin, TomTom, and Magellan) So I am guessing I just corrected the factory tolerance...
I also register 60mph on the roadside radar units when traveling at 60mph on the speedo.
Not sure if it would hold up if Chrysler were to question it, but I am confident with my speed.
Old May 5, 2008 | 08:13 PM
TEEJ's Avatar
Talking
Depending upon the specific tire, that makes sense, as the 305/70/16 is a 33-ish tire, so compared to the 32.1" oem tire, 33" nominal sizes can be less than an inch different....which, based upon the factory's 3% margin of error...the tiny < 3% difference between a 33 and a 32 can be easy absorbed by that margin...so that, in effect, the new tires corrected the prior factory margin of error, bringing the speedometer/odometer calibration to a dead nuts resolution.
That happend on another truck I had, the damn thing read high, I upped the tire size, and it read correctly...all due to the original factory variation.
