Ok, what else do I need.
I went ahead and decided to pay a local shop to install a 2.5" pro comp lift with fox shocks. He also suggested a Terraflex front track bar and bigger steering shock to help with the DW. Is there anything else you guys can recommend I get installed while they have my jk?
Thanks |
I wouldn't really recommend the ss, but I would go ahead and ask them how they intend to torque everything on it I've the lift is on. I.e. making sure they let it off the lift before torquing the trackbar.
Might want a set if adjustable control arms front and rear. Sent from my DROIDX using Tapatalk |
Interesting note on the tightening off the lift. Just curious as to why the ss is not needed. I am clueless. And the adjustable arms, is the same as track bars?
people believe that the stock ss is just as good as any aftermarket ss. unless your stock ss is leaking.
no. an adjustable trackbar centers your differential as the control arms pushes the two front wheels further away from the rear wheels. |
maybe i should have said that people believe the stock ss works just fine unless it is broken. it probably isnt better then any aftermarket ss...
| All times are GMT -8. The time now is 10:29 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
