Sponsored by:
Sponsored by:
regearing
Old 11-27-2017, 02:00 PM
ali81's Avatar
Default regearing
i have just bought a 2008 wrangler unlimited, the car had engin swap with hemi 6.1 and supercharger. the transmission is 6speed manual which according to the previous owner is from a deisl jeep and cant take up to 1000hp. the main question is i have to replace the broken ring and pinion which was 4.88 but the mechanic advised me to go for 4.56.
i know that mechanic had never seen a wrangler with such modifications
can anyone advise me what ratio should i choose
Old 11-29-2017, 08:32 AM
Ifstew's Avatar
What size tires are you running? What type of driving are you doing? Highway, city or off roading?
Old 11-30-2017, 06:07 PM
TheTerminator's Avatar
With 6.1L and a supercharger I don't see why you need such low gears. Are you running 54" tires??
Old 12-01-2017, 05:17 AM
Canvas's Avatar
What axles are you running? If you have stock or 44's you will continue to break ring and pinions. I would recommend an D80 (one ton's) at a minimum with that much horsepower. You need a bigger ring and pinion.
R/
Will
Old 12-02-2017, 03:32 AM
BRinSCupstate's Avatar
With that motor; I'd try to determine what cruising RPM would be optimum with the tire size you plan to run and gear for that RPM. I have an LS 6.0 with GM transmission. I was targeting around 1800 at 70mph with 35". My 6th gear ratio is probably different than yours but I have 4.10.
Quick Reply: regearing
