Options... Options...
Well last Sunday I went offroading with a buddy of mine and in the process I ended up doing some decent damage to my front axle housing. I'm looking at either replacing it with a stock Chrysler dana 44, repairing mine and welding in gussets and trusses to strengthen it, or purchasing a dynatrac 44 and putting my gears and lockers in it. I'm trying to do this on the cheap and get it back on the road asap. I'd like different people's opinions that have been through something similar, and would also like to hear more suggestions if there's something that maybe I'm not thinking of.
I haven't inspected everything yet, but here is a list of the known damages as of right now:
Front passenger shock is shot
sway bar links are shot
Lower passenger control arm is bent
lower passenger control arm bracket that attaches to the axle housing is broke
upper passenger control arm bracket that attaches to the axle housing is bent
both front axle shafts are broken (the ears)
trackbar may be bent
tie rod may be bent
passenger C may be bent
As of right now I don't know if the axle tube is bent or not... gonna look in to that this weekend.
tie rod may be bent
tie rod may be bent
tie rod may be bent
Sponsoring Manufacturer
If your looking at getting it fixed asap I would check with David at Northridge 4X4 for the PR44. Last time I was there he had them in stock. You probably won't be able to beat the price either
