Ordering lift in about an hour need some help
when you lift a vehicle, the axles move towar eachother because of the connected arms, the new adjustible arms can let you push the axles back to the center of the wheel well. Not really important on a 4 door because the wheel base is so long, but on the 2 door it is best to have as much room in between the axles as possible.
i think (im learning too)
Your not going off roading! So all you need is 33''s
I have a silly question...
WHY IN THE CRAP would you buy a 2x4 jeep!!!
For that matter, why would DC EVER produce a 2x4 jeep!!! AUH the humanity..
And then you want to Lift it?!?!?!? WTF for?!?
As far as lifting...I believe we all want to drive around in a cool ride, otherwise we would have bought Kia's.... the bigger tires just add to the cool factor
Ah, get off the guy's back. If you guys want to yell, then go yell at the guy wanting to put on 40's just to impress his neighbors.
But, actually, 2K2, you're not entirely correct either. A 3 inch lift and 33's ARE actually enough to throw off his caster angle, and could cause his steering to be shifty. Maybe only by a degree or two, but enough to make a difference in a vehicle that's gonna be driven on the highway carrying his family. The non-adjustable arms could be perfect length; I'm sure you've got all the numbers in front of you, though, showing alignment limitations and technicalities.
Driveshaft angle's not what we're talking about here. A 3 inch extended arm will alter the driveshaft angle, but all that's gonna do is cause vibration. He doesn't have a front driveshaft to wobble (which wouldn't matter for 4x4's either unless they were in 4HI on the highway). And the rear shouldn't wobble greatly with a 3-inch extended arm, either. (Which would be nice if someone reported.....) However, you are correct that a 4-door, having a longer wheelbase, would be less affected.
If I'm wrong, then I'm wrong.
JK-Forum Founder
Yeah, you're right. I forget that they're non u-jointed.
It's gonna be interesting to see how folks treat those. From what I've heard, at reasonable lift amounts, they can actually be superior as long as they're maintained. But, there are clearance issues with them, of course.
I'm also wrong in that you won't be able to disengage the front driveshaft on the 4x4 models, because of the lack of selectable hubs.
Thanks for the correction.
By the way, WOL, swing over by my thread in the stock room, please, and answer a few questions.
DC is producing it, and my freind, they are selling them.
As for all with two wheel drive Jeep's welcome to the site!
JK-Forum Founder
Yes, you most certainly can, but I honestly wouldn't recommend it. Cam bolts have a reputation of never staying on tight enough and always come loose. In fact, that's why Jeep stopped putting them on TJ's from the factory back in 97... in other words, the first year the TJ came out.
