Orfab tire carrier
So I was calling around to see if the cost of getting this installed vs. me buying the tools to install it myself would be worth it. One shop suggested I cancel my order because "everyone they have seen rattles like crazy" I'm not sure if this is the truth or this guy trying to get me to buy something else from them. So who here has one? How long have you had it? And what complaints do you have?
I have the version that also carries two Jerry cans. Installed a bit more than one year ago. Used with the cans empty and full, 33 and 35 tires. No rattles at all.
It's well built and can stand a lot more weight if installed properly.
Only issue I have with it is finishing. They did not do a good job and it shows several rust spots. I was planning to repaint it this Summer but other priorities postponed the plan since the rust is more superficial and can wait.
Installation is a pain. Took me almost a full day to do it alone and triple-measuring everything. I'm sure experienced folks using another pair of hands would do it in a few hours. If you are handy go for it. Tools needed were a good measuring tape, good set of drills and a small driller (I used my small Bosch) and a socket ratchet wrench set. Nothing special.
I would buy it again and install it by myself again. Only thing I would do different is applying a couple layers of paint before installing.
Had mine a few years, no rattles. Agree with the rust issue... It's not that bad. Majority of mine is at the catch & latch. Nothing some rust inhibitor & paint won't fix. Install definitely was a PITA, took my bro and I 4-5 hours. Its one of those install projects that you take a lot of pride in completing! It can hold a lot of weight and having a place to store rotopax is a plus.
Install was a pain but the quality is awesome. Not sure why some peeps are having their tire carrier rust like crazy. I got the rotopax one and this thing is solid and no rattles what's so ever. I highly recommend it and also get corrosion x if you are paranoid about surface rusting and spray the latches down. I also recommend plugging up the mounting holes as well so water doesn't get in it.
I've had mine for about a year and a half. Carry a 37" tire on it and so far no problems. It doesn't rattle and still operates smooth and quietly.
I don't know what issues others are having with finish but all my OrFab products are holding up great. I have front and rear bumpers, tire carrier, and third brake light and the powder coat has held up great with no rust showing. Now on the hinges and latch of the tire carrier I do spray them with some WD-40 periodically which helps keep it working/moving smoothly and rust free.
Been running the can style one for almost a year with only a 35 on it and cant stand it. Rattles like crazy, rusted within a week of getting it. Looking at getting a EVO style on made up using EVO skins.
