PCV/CCV Hose to Airbox disconnected runs MUCH better??
ok, here is the question of the day. I have 13k miles on my 2011JKU. I installed a snorkel two weeks ago and forgot to connect the breather hose back to the airbox. It ran so smooth. I was checking over everything yesterday and noticed the hose was off. I reconnected it and the idle is rough...any thoughts? I was thinking it ran like that for two weeks and maybe the computer needs to re learn
I dont think so, I will look. Its the hose at the side of the airbox, maybe just a vacuum or breather hose? Any insight
Thinking about how the system works, I can't come up with a reason for what you are seeing.
With the hose disconnected, the end is exposed to atmospheric pressure.
With the hose connected to the air box, it's exposed to probably only slightly less than atmospheric pressure. I'll bet you can't measure the difference without a good water manometer.
All it's doing is drawing air through the crank case, into the intake.
I'm not saying there isn't something going on there; it just seems unlikely it should make a difference.
I know I have forgotten to reconnect the same line on mine, and saw no difference.
What you should do for the sake of experimentation is see if you can repeat it several times. (Hook it up, get rough idle; disconnect it, get smooth idle.)
