Originally Posted by 2010 Sahara unlimited
(Post 3664370)
Do yourself a favor. Go to 35" with the 2.5" teraflex bb. You will have zero regrets.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=493601"/> |
4 Attachment(s)
OME lift with cooper discoverer STTs
Sent from Chew Crew HQ |
2 Attachment(s)
17x9's
GY MTR Kevlar 305/70/17's Teraflex 2.5 coil lift |
Originally Posted by SpicedCrusher
(Post 3663599)
No. My wheels have 4.75" of BS and no rubbing. Well it did rub on that plastic arm dam at the bottom of the stock bumper. You can however remove it or just trim what you need to. I eventually went to a JCR bumper so didn't have to worry about it anyway. |
2 Attachment(s)
Teraflex 2 1/2 coils and shocks (4dr)
Toyo MT 285/75/17 |
Originally Posted by 09Rubicon24
(Post 3664799)
Sorry if this question is dumb I'm trying to get a better understanding of how back spacing works... If wheels had 4.5" back spacing instead of 4.75 would they still rub... Also if I don't have a lift will 28/75/17 fit with right wheels thanks for the help
I ran that for a couple of months and then I added the bds 3" lift Matthew |
Originally Posted by amick218
(Post 3664409)
That's so sexy! Love that color |
2 Attachment(s)
(Post 3664799)
Attachment 494621 Attachment 494626 |
2 door JK with 285/75R16 fierce attitude tires and old men emu HD lift 2.5"
1 Attachment(s)
you didnt specify 4 or 2 door.. so here is mine..
2 door JK with 285/75R16 fierce attitude tires and old men emu HD lift 2.5" Attachment 494627 |
(Post 3667090)
No problem. Took me a bit to get my head wrapped around BS as well. The stock JK has a BS of around 6.25" I believe. When you lessen the back spacing basically the tire sits out past the fender and is less likely to rub. 4.5" of BS is ideal you will not rub nor will 4.75. I don't have 285's so I am not certain if they can be run on stock wheels without rubbing but I can't see why not. Try test fitting one and seeing first. But if you have 4.5" of BS you will be good to go. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=494621"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=494626"/> |
