Plasti-Dipping Rims this weekend. Have a few questions...
Hoping this is the right place to post these questions...
I looked up prior threads but still had a few questions....
On average how long does it take to complete doing all 5 rims?
What problems have you ran into?
Any downsides to doing this?
Did you do the lugnuts as well?
I am hoping its a nice weekend and I do this project this weekend.
How do you wash the rims when they are done? Any special products?
How long did it last before they peeled?
Thanks in advance!
Thanks in advance!
Its easy to do. I did it with them still on the vehicle. Just make sure you use at least 5 coats and clean the wheels beforehand. If I could do it over again, I would have sprayed the entire wheel and tire. I just did the wheel and it made it difficult to peel the overspray from the tires. After a day of driving and seeing the leftover plastidip (that i couldnt peel off by hand) on the tires, and i got a junk rag out and scrubbed the rest of it off. Makes a huge difference in the look of the vehicle. I did it to take away some of that "HELLO I'M BRAND NEW JEEP" look.
I did my wheels and hinges.
To answer your questions
it took about 4 and a half cans
the thicker you put it on the easier it is to pull off (i put on about 5 coats)
Its very very easy to put on.
I did not to the lug nuts or center caps. I figured i would mess up the finish re-installing them
I waited about 10-15 min between coats and gave it a few hours before trying to re-install them
the only problem i ran into was applying it to one of the too thick and got a run in it. I waited until it was dry and peeled it off. Easy.
It WILL look textured when you are applying it but it smoothes out between coats nicely.
I wash them with my regular car wash and a sponge.
I hear it will last about a year. I have had mine for about 6 months and have abused them and they are holding up great.
Use denatured alcohol to clean them first. That'll help it stick. I used 3 1/2 cans for 5 wheels, only did 2-3 coats, and used playing cards wedged btwn the tire & rim (before I was informed the stuff would peel off the rubber easily). I did spray my lugnuts, but used a toothpick to score around it so the dip wouldn't peel off on my next tire rotation. Been a couple months and still holding up. Power washer didn't do any damage whatsoever.
The day I did it:
3-4 months after dipped:
Btw, only took me about an hour total to do all 5 wheels. I did my spare first, then both drivers side at same time, then passenger. Some people don't care about overspray, but I shoved paper towels behind the wheel to protect the brakes & rotor from getting gunked up.
The day I did it:
Can't afford new rims/tires right now and looking for a different look for mine. This sounds like a super easy cheap mod and looks great!
The day I did it:
Attachment 329226
Attachment 329225
Attachment 329227
The day I did it:
Attachment 329226
Attachment 329225
Attachment 329227
And thank you BOTH for posting pictures. Kind of sealed the deal for me.
Thats what SHE said...
The day I did it:
Attachment 329226
Attachment 329225
Attachment 329227
The day I did it:
Attachment 329226
Attachment 329225
Attachment 329227
Originally Posted by DeucesALLin
Ebay snorkel, bedlined wheels/hinges, and SPACERS... hucentric or not is the Q: RC or ST?
I am really wanting to get the snorkel, but have a CO trip maybe planned in a month. Gas to party in CO or snorkel?
As to the wheel painting: i used bedliner. Same process.
I cleaned good, then sanded down, cleaned again, then wiped down with Mineral Spirits.
Once it evaporated, I sprayed a coat of Self Etching primer since I had a can laying around.
Then did 3 coats.
Held up perfectly. Also did my lugnuts. They held up great the first 10 times I removed them, but as soon as i got sloppy with the 4-way it'd slip and chip the edges shiny again.
I also did my hinges, didn't sand or primer them. And my key hole too since i'm doorless mostly or key fob to unlock.
MORE pics in my album of the whole process and all the stuff I used.
Then did 3 coats.
