Please help quickly...
Old Jan 9, 2009 | 07:32 AM
In5ane's Avatar
Default Please help quickly...
I installed my superlift 2" BB last night and had ordered the shocks to go with it. However, after comparing my shocks with the stock factory shocks..they weren't any more than maybe 1/2 inch longer. They are almost maxxed out just being mounted on the vehicle. I called superlift and they refused to believe the shock was that short. They said their shock should be about 2" longer than the factory. But that wasn't the case. They won't even send me replacements until I send these back...wtf???
Anyone had this problem????
Old Jan 9, 2009 | 07:34 AM
cyberbrain's Avatar
was the shocks at full extension?
Old Jan 9, 2009 | 07:39 AM
In5ane's Avatar
when i measured...or when installed?
Old Jan 9, 2009 | 07:52 AM
cyberbrain's Avatar
measureed.
Old Jan 9, 2009 | 08:01 AM
In5ane's Avatar
I didn't measure the shock itself, but it's not longer than stock...When mounted on jeep it's 21" from mount to mount. I think it should be 23" total..?
Old Jan 9, 2009 | 08:02 AM
In5ane's Avatar
Originally Posted by 2k2wranglerx
Stock front shock: 14.5" Collapsed/22" extended.
Skyjacker SJA-H7025 for 33.99
Extended Length (in): 24.750 in.
Collapsed Length (in): 14.540 in.
Should be good for about a 2" lift. But CAN be run stock! collapsed length is similar to stock, but has more travel.
store.summitracing.com/partdetail.asp?autofilter=1&part=SJA%2DH7025&N=700 +4294919396+4294903032+4294908280+4294907384+42949 24642+4294908098+115&autoview=sku
Here they are in NITRO for 39.99
store.summitracing.com/partdetail.asp?autofilter=1&part=SJA%2DN8025&N=700 +4294919396+4294903032+4294908280+4294907384+42949 24642+4294908098+115&autoview=sku
Skyjacker SJA-H7049 33.99
Extended Length (in): 28.750 in.
Collapsed Length (in): 16.560 in.
These would be for a MINIMUM 2" lift. Or you could adjust your bumpstops. This would be ideal for a 2.5-3" lift
store.summitracing.com/partdetail.asp?autofilter=1&part=SJA%2DH7049&N=700 +4294919396+4294903032+4294908280+4294907384+42949 24642+4294908098+115&autoview=sku
thanks for the info, but should they have sent me the correct shocks? I mean I paid for shocks to match the lift...isn't that their error. They said they will send me longer one's, but I have to send mine back first. That sucks...
Last edited by wayoflifette; Jan 9, 2009 at 08:09 AM. Reason: edited clickable links
Old Jan 9, 2009 | 08:05 AM
In5ane's Avatar
see above. pretty sure 22" was max extended. any one of the shocks above would work for ya.
I usually buy lifts without shocks and then do the measurements myself. the ones that come with the kits seem to error on the short side.
my experience is that lift kits generally include shocks that run on the short side.
Thanks for the info, they are gonna send me longer shocks....what a freakin' mess...oh well, so it goes I guess!
Old Jan 9, 2009 | 08:06 AM
In5ane's Avatar
now that measurement is from where to where?
Old Jan 9, 2009 | 08:08 AM
MJS_Jeep_888's Avatar
Tell them to include a return shipping label when they ship you the correct shocks, and they'll get their mistake back.
Old Jan 9, 2009 | 08:19 AM
In5ane's Avatar
Well, they made the comment that everything up to an 06 wrangler fit fine....wouldn't the stock shocks on a wrangler jk be taller since the jk comes with more clearance than a TJ????
