plz help..
I took my car today from the shop.. I placed an OME suspension ARb lsd front and back, 4.88 gears. my car is 3.8 automatic 2door.
The problem is that when I go to the highway and I reach 55-60mph the whole cars starts to vibrate so much that I cant drive… (I have to slow down and then it stops..) it moves right and left all the time like my suspension goes right and left really fast. also the sterring whell goes right and left very very fast… if you see the car outside I think it is all shaking… At first I thought it was something wrong with my wheels.. and from that time, any time I reach 55-60mph it does it again.. every single time… I am sure it is going to break.. I cant even go straight... !!! lool it is funny :eek2::eek2: I have the stock 32tires. without spacers.. yet Do you have anything in mind?? I will try to drive it again slowly and take it back to the shop i installed all the things.. The problem is that i dont know if it is from the gears from the arb diffs or from the suspension...:crazyeyes: any ideas ? Thank you for your help, Nick |
I don't understand the problem. Take it back to the shop that did the work.
1 Attachment(s)
Originally Posted by pansil
(Post 1421560)
The problem is that when I go to the highway and I reach 55-60mph the whole cars starts to vibrate so much that I cant drive… (I have to slow down and then it stops..) it moves right and left all the time like my suspension goes right and left really fast. also the sterring whell goes right and left very very fast… if you see the car outside I think it is all shaking… At first I thought it was something wrong with my wheels.. and from that time, any time I reach 55-60mph it does it again.. every single time… I am sure it is going to break.. I cant even go straight... !!! lool it is funny :eek2::eek2: I have the stock 32tires. without spacers.. yet Do you have anything in mind?? I will try to drive it again slowly and take it back to the shop i installed all the things.. The problem is that i dont know if it is from the gears from the arb diffs or from the suspension...:crazyeyes: any ideas ? Thank you for your help, Nick It's not your gear or diffs. The first thing I thought was the tires need balanced, but if this just started happening after the lift was installed, it's probably not the tires... How much lift is the kit? Did you install it yourself? Did you replace your trackbar with an aftermarket one or relocate it? |
speed related shimmy is typically a wheel balancing problem. however, if it's more of a violent shaking and to the point where you really cannot drive until you come to a stop, your shop probably didn't install your track bar correctly and/or tighten the bolts to the appropriate torque setting.
tank you for the quick reply.. the car has the Medium Ome front and hard back (I still havent placed a rear bumper) and it is too tall back... I took the packege from Northbridge and I installed brakelines and sway bar links front and back.... :what?:
(Post 1421582)
tank you for the quick reply.. the car has the Medium Ome front and hard back (I still havent placed a rear bumper) and it is too tall back... I also have installed brakelines and sway bar links front and back.... :what?:
they also told me that for some reason they didnt manage to place the sway bar links in front because they didnt fit?!:dontknow2: and they placed only back sway bars and in front they left the stock.. ...
So the good think is that you all believe it is a suspension problem and not from the 4.88 or the lsds... |
(Post 1421644)
So the good think is that you all believe it is a suspension problem and not from the 4.88 or the lsds... Did you just add the LSD to the front? The rear should come with it from the factory... |
(Post 1421644)
(Post 1421644)
So the good think is that you all believe it is a suspension problem and not from the 4.88 or the lsds... As the others have said, it is likely a trackbar issue. Have them tighten up the bolts on the front trackbar to 125 ft/lbs, with the JK on the ground. (If the bolts were tightened while on a lift with the suspension drooping, have them loosen the bolts and re-torque while on the ground) |
| All times are GMT -8. The time now is 01:13 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
