Powder Coat Question
Old May 18, 2012 | 08:54 AM
Prime8's Avatar
Originally Posted by mOjO_JK
How about using self etching primer....I think that's what its called.....is that any better than just using a primer?
A self etching primer provides better adhesion if you have a fairly smooth surface to paint. It's a must for polished steel or aluminum if you aren't going to sand blast.
Old May 18, 2012 | 09:24 AM
mOjO_JK's Avatar
Originally Posted by jaker t5
or you can get the bumper sand blasted and re paint yourself , i had to do that on my front bumper
right after sand blasted
after i bedlined it
That looks sweet!...what's did u bedline it with?
mOjO_JK's Avatar
This is all good to know....cause I plan on getting a bumper and the one I want comes bare metal from poison spyder
Old May 18, 2012 | 10:27 AM
Prime8's Avatar
Those are the bumpers I'm looking at getting eventually too. Want to paint them an accent color, but for easy touchup reasons, I'll probably keep them black... If you want to evaluate powder coaters, ask them about their process. Almost everyone does a one coat process, which is where most of the headaches come from. Powder, when melted, becomes a liquid. Due to surface tension and fluid dynamics, liquids don't typically round sharp corners. Therefore, a one step powder coat leaves a very thin layer at any sharp corners that introduces a weakness and easy failure mechanism built-in! The proper way to do it is to apply the first coat and put it in the oven. When it becomes semi-amorphous (ie gooey, but not yet watery) you apply a second coat that sticks to the first coat and allows much better corner coverage, since the gooey powder doesn't pull away from the corners as much. Then they need to finish baking and curing it while its still hot.
Old May 18, 2012 | 10:19 PM
jaker t5's Avatar
Dupicolor bedliner
