Which PR44 setup and why?
In a few months I will more than likely be upgrading to a pr44, seeing as how my stock d30 housing is bent and I don't want to waste money on it. I'm trying to gather facts together over the next few months as to what pr44 I should get (reg or unlimited), where I should buy it, and what internals I should run.. So far I have just looked on northbridge4x4 at their unlimited package which can be preassembled. I want to be able to simply order one fully assembled and bolt it in utilizing my d30 knuckles, brakes, etc. Any suggestions?
i would get the unlimited and not just because the tubes are so much thicker but, because it also comes with outboard shock mounts and built in positive caster. it's definintely the way to go :yup:
1 Attachment(s)
That's what I just got! Unlimited is definitely the way to go! Get the better ball joints too! Worth it in the long run.
I'll be ordering one here soon too. I'm going unlimited. I think the biggest debate is to run RCV axles or chomolly with u joints. Also something to consider is Ried Racing knuckles. I think I'm going that route also.
As others have stated, the Unlimited version is your best option. It can be set up with any of the popular lockers and the added caster will help get your steering angles back to stock or better.
I spoke with literally dozens of PR44 owners in Moab and, without exception, they raved about the better handling. Feedback like that makes the PR44 easy to recommend. Scott |
Hmm well I think the unlimited is the obvious choice then. Would a truetrac work with the unlimited?
Originally Posted by XBlacky08X
(Post 2255298)
Originally Posted by Dynatrac
(Post 2255345)
Yes, a Truetrac will fit. The part number is 913A589 (JK 44s use a 'thick' gear so they use the 3.73 and down case, not the 3.92 up.
Originally Posted by Jknockers
(Post 2255373)
What about locking hubs? Don't want everything spinnin when I'm runnin down the road
I'd love to hear if locking hubs are a good or bad idea for the JK as well. |
(Post 2255345)
