PRESS RELEASE: Off Road Evolution JK LinXLok
If you've got a lifted Jeep JK Wrangler with a set of adjustable lower control arms, you know how hard it can be to keep the jam nuts on tight and in place. Thanks to its size, finding a wrench large enough to fit around them can be difficult and with things like your control arm mounts in the way, this can be almost impossible to do especially when you're on the ground and on your back and with very little room to work with. Fortunately for us, Off Road Evolution has just released an incredible patent pending solution to this annoying problem and it is the all new EVO LinXLok.
Manufactured out of alloy steel and zinc plated, the EVO LinXLok is designed to utilize a pinch bolt as well as 4 set screws that are angled inward to bite into any aftermarket adjustable lower control arm using a standard 1-1/4" - 12 threaded joint. With the final addition of a rubber O-Ring that helps to keep water and debris out of the control arm, the EVO LinXLok is simply installed onto your control arm joints in place of your existing jam nuts. After setting your control arms to the desired length you need, all you need to do is hand tighten the EVO LinXLok, secure the pinch bolts and fasten the set screws and you're pretty much good to go. No additional tightening of the EVO LinXLok is required and initial tests have shown that with just this minimal amount of tightening alone, an impressive 125 ft. lbs. of torque or more would be required to loosen up the nuts. Needless to say, with a set of the EVO LinXLoks on your adjustable lower control arms, you can pretty much install them and forget about them.
Click on the screen or link below to watch a short demonstration video on how the EVO LinXLoks work - be sure to watch this YouTube video in HD!!
Off Road Evolution JK LinXLok YouTube Video
To see more photos of the Off Road Evolution EVO LinXLok, click on the link below:
Off Road Evolution LinXLok Photo Gallery
The Off Road Evolution LinXLok can be purchased individually (1 right hand thread, 1 left hand thread) for $30, as a pair (2 rights, 2 lefts) for $50 or as a complete set of 4 (4 rights, 4 lefts, 2 rights, 2 lefts) for only $100 and free shipping. Order yours today!
http://www.offroadevolution.com/stor...cts.php?cat=22
For more information about the EVO LinXLok or any Off Road Evolution Product, please visit their website at: www.offroadevolution.com
