Originally Posted by Hack
(Post 4299034)
That's one point...but the Super chips Flashcal also serves as a code reader, can change a whole lot of Factory presets like DRL or lane change features and can also serve as an engine idle boost if you would add a winch later on. Plus it can be later upgraded with tuner software. Seemed worth it to me....but I installed 35's...
Originally Posted by ShutterBug
(Post 4299044)
The OP mentioned a ProCal for a speedo "fix", which is to what I was responding, not sure why you picked my post to troll. And I can read codes with a $20 OBD II WiFi/Bluetooth adapter and a free app for my phone. I have a winch, use it, and never needed to boost my idle speed. $170 so I can have DRLs (since I already have lane change in my 2014) is still a waste for me.
(Post 4299030)
From 32" to 32.7" you would be wasting $170.
Originally Posted by zstairlessone
(Post 4299047)
But the OEMs aren't really 32"
(Post 4299044)
I agree with you and jedg though, such a marginal difference in tire...there's no point. I only bought the ProCal when I regeared...then I figured I might as well calibrate the speedo too. Never was a problem though, so part of me still feels like $170 went down the drain. Whatever :dontknow2: I used it 1 day, and threw it back in the box. Have no clue where it is anymore, that's how often I "need" to mess with meaningless things. I've also used this Warn PowerPlant enough to fry the solenoid (replaced it, sucked), and I've never needed an engine idle 'boost'...whatever that is. |
Good points as always on here. If the speedo is close and it shifts okay tomorrow on the work drive, will use that $170 elsewhere.
Originally Posted by Millerca2
(Post 4299062)
1. Download a GPS app and check your speed against that. 2. Use the highway mile markers... go 60mph based on your speedometer... then time from one mile marker to the next.. you should be at 60 seconds for each mile. |
I have had the opposite experience as some, I have used my procal on 3 different vehicles since 2012. I just used the restore feature when I traded. I like drl and I like my speedo and odometer/tripometer to be accurate and like to run 28psi with out nanny lights coming on.
The idle boost feature keeps your battery charged during heavy winching so not a feature many would use but nice if you need it also runs the air compressor a little faster when airing up. Also upgrades are a sickness so 285/70 lead to 35's which lead to gears the procal does that too. Also some of us who end up fubared rubicon electric discos can use the procal to remove it from the system without having to look at the flashing disco light . $170 pretty cheap in the grand scheme of jeep mods. |
$170 is nothing compared to the price you pay to have more or less the same features in other platforms, even if it was just to fix the revs per mile issue when you switch to bigger sizes or change your gears. Also if i remember correctly, the factory Rubi KM2's measure 30.5", doubt the factory Sahara Duellers in 255/70/18 will be taller than the Rubi KM2's?, My KO2's in 285/70/17 measure 32 1/8" mounted in 17x9 wheels, sure enough to mess with your speedo and mpg if you care about that, and/or if you have a auto trans, it may mess your shift points, though i ran that size for about 2 months or so, before i use a Flashcal to correct for the new size, and i don't remember having issues with my shift points, don't know if the size will be an issue in the long run if you didn't correct the size in the calibration.
Also, tire size is a fairly debated subject, most people think their tires measure the same as advertised size, or will use the math to convert the size label into diameter, none of this will account for weight under the tire and wheel width. Waytocry has a nice database with height measurements, along with pictures and how to measure your tires, i think a lot of people will be surprised to know what their tires really measure, vs what their advertised size was, or how the tire look like compared to others here https://wayalife.com/showthread.php/...l=1#post838259 So for For example GY Duratracks in 285/70/17, 31.5" https://wayalife.com/showthread.php/...l=1#post774508 BFG KM2 in the same size, 31.5" https://wayalife.com/showthread.php/...l=1#post685769 Nitto Terra grapplers in 295/70/17, advertised 33.31", measured under the Jeep, 32 1/4" https://wayalife.com/showthread.php/...l=1#post713360 Cooper STT Pro in 295/70/17, measured at 32" https://wayalife.com/showthread.php/...l=1#post717246 Cooper STT Pro in 315/70/17, 33 1/4" https://wayalife.com/showthread.php/...l=1#post866935 Mickey Thomspon MTZ in 315/70/17, 32 3/4" https://wayalife.com/showthread.php/...l=1#post797002 My Nitto Trail Grapplers in 315/70/17 measured 33.5" brand new at 28PSI https://farm5.staticflickr.com/4239/...64277555_h.jpg2017-07-08_10-18-13 by Wrangler RSM, on Flickr My old KO2's in 315/70/17 with 42k miles measured 33 1/4", 33.5" brand new at 32psi. BFG KO2's in 35x12.5x17, 33 3/4" https://wayalife.com/showthread.php/...l=1#post663567 GY Duratracs in 35x12.5x17, 33 5/8" https://wayalife.com/showthread.php/...l=1#post663839 Kanati mud hogs in 35x12.5x17, 33 1/2" https://wayalife.com/showthread.php/...l=1#post835317 Nitto Trail Grapplers in 35x12.5x17, 33 1/2" https://wayalife.com/showthread.php/...l=1#post679755 Toyo MT 35x12.5x17, 33 5/16" https://wayalife.com/showthread.php/...l=1#post663745 Nitto Ridge Grapplers in 35x12.5x17, 33 3/8" https://wayalife.com/showthread.php/...l=1#post812817 Wanna check the monster looking 37's? How about Nitto Trail grapplers in 37x12.5x17, 35.5" https://wayalife.com/showthread.php/...l=1#post674427 Toyo MT's in 37x12.5x17, 35 5/8" https://wayalife.com/showthread.php/...l=1#post857354 Cooper STT Pro 37x12.5x17, looks 35.5" to me, https://wayalife.com/showthread.php/...l=1#post837285 Poor KM2's in 37x12.5x17, 34.75" https://wayalife.com/showthread.php/...l=1#post722297 |
Originally Posted by BoraBora
(Post 4299055)
He just wanted to justify his waste of money, and let people know about his "sick" 35's.
I agree with you and jedg though, such a marginal difference in tire...there's no point. I only bought the ProCal when I regeared...then I figured I might as well calibrate the speedo too. Never was a problem though, so part of me still feels like $170 went down the drain. Whatever :dontknow2: I used it 1 day, and threw it back in the box. Have no clue where it is anymore, that's how often I "need" to mess with meaningless things. I've also used this Warn PowerPlant enough to fry the solenoid (replaced it, sucked), and I've never needed an engine idle 'boost'...whatever that is.im I don't have a need to justify anything I do...I was was just adding the other benefits the Flashcal has to offer. Is that $20 dollar code reader going to benefit a re- gear ...no..is that app going to change the low tire pressure threshold...no...just saying it has it's benefits...and by the way ... I only stated I had "sick" as you put it, 35's because my scenario was different....just sayin'....🤐 |
