Procal problems
Old Aug 23, 2012 | 08:23 PM
Zenabi's Avatar
Default Procal problems
I'm trying to get my tpms light to go off but my procal isn't taking it off I have 31 pounds in my tires an I set the low pressure at 28 anybody know something I'm doing wrong?
Old Aug 23, 2012 | 08:44 PM
texascodmw3's Avatar
Did you check the spare?
Old Aug 23, 2012 | 08:47 PM
Zenabi's Avatar
Yes sir crazy thing is I get the honks but it still doesn't go away !! :(
Old Aug 23, 2012 | 08:54 PM
Hmmm. Maybe put more air in the tires to see if it goes off. Perhaps a calibration issue between your gauge and the sensors.
Old Aug 23, 2012 | 09:36 PM
Rich6700's Avatar
Inflate the tires to 40psi drive it around the block then lower the tire pressure to where you want it.
Old Aug 23, 2012 | 10:55 PM
Northridge4x4's Avatar
Sponsoring Vendor
You need to lower it farther if I remember correctly you need to be approx 5 psi lower than your tires for the light to turn off
David
