Prorock 44
I'm having an issue with seal leaks and can't figure out if my aftermarket knuckles or aftermarket Ball Joints are the cause. My Axle Shafts sit high (3/16") on both sides where they exit the housing tubes into the knuckle area, like there is much less space above them in the axle tube than below.
OP, what axle shafts are you running in that housing? I'm running a ProRock 44 Unlimited, Prosteer ball joints, RCV axle shafts, and Rancho knuckles and have zero leakage or issues.
Please let us know if you get it resolved, my prorock is setup with rcvs and reid knuckles and prosteers haven't seen any leaks yet but would like to know whats causing yours....
What axles are you running? What locker? Some combinations end up with shafts with a poorly located seal area. I'd check the axle seal surface in relation to the actual seal location.
