Sponsored by:
Sponsored by:
Prorock 44
Old 05-23-2017, 09:49 AM
Biginboca's Avatar
Originally Posted by DJ1
Oh no, here it comes. The moment of truth....
So true! I'm on the edge of my seat lol
ktoth87's Avatar
Running the factory knuckles. How does that affect the leak?
Old 05-23-2017, 09:51 AM
Biginboca's Avatar
I'm having an issue with seal leaks and can't figure out if my aftermarket knuckles or aftermarket Ball Joints are the cause. My Axle Shafts sit high (3/16") on both sides where they exit the housing tubes into the knuckle area, like there is much less space above them in the axle tube than below.
Old 05-23-2017, 10:11 AM
DJ1
Former Member
DJ1's Avatar
What ball joints you running?
Old 05-23-2017, 10:17 AM
ktoth87's Avatar
Synergy ball joints. Which are good. No play in them.
Old 05-24-2017, 05:06 AM
Ryan0260's Avatar
OP, what axle shafts are you running in that housing? I'm running a ProRock 44 Unlimited, Prosteer ball joints, RCV axle shafts, and Rancho knuckles and have zero leakage or issues.
Old 05-24-2017, 08:16 AM
ktoth87's Avatar
I want to say they are yukon or g2. Honestly can't remember I'd have to try and pull up the receipt
Old 05-24-2017, 09:20 AM
blowermax's Avatar
Please let us know if you get it resolved, my prorock is setup with rcvs and reid knuckles and prosteers haven't seen any leaks yet but would like to know whats causing yours....
Old 05-24-2017, 01:52 PM
Digger 5's Avatar
What axles are you running? What locker? Some combinations end up with shafts with a poorly located seal area. I'd check the axle seal surface in relation to the actual seal location.
Old 05-24-2017, 01:54 PM
ktoth87's Avatar
I have to check for my receipt on the shafts but I have an ARB.
Quick Reply: Prorock 44
