PSI on GY Duratracs?
i'm running the GY DTs on aluminium wheels, rugged ridge front stubby and side rails, or-fab tire carrier.
the tires shipped about 500 pounds and i'm guessing another 250 between other things..
When I asked about weight, I was referring to your Jeep (complete with bumpers, armor, etc.). The amount of weight that you're carrying will affect what the correct inflation level is for your tires.
Just installed Duratracs and they have a Load E rating. It says 80 psi on the tires. The ride is so rough it feels like the jeep is going to rattle apart. I lowered the pressure to 70 and it helped a bit. I read if the pressure is too low it is unsafe? Are you guys running 35 psi on Load E rated tires?
Thats max pressure!
I have toyo 37's load rg E , I run 26-28psi
