PSI on GY Duratracs?
If I take a long trip, I bump mine to 30psi, otherwise I run 26-28 all year round.
Get a piece of side walk chalk rub it over the width of the tred. Drive the vehicle for a 100 ft. or so. If the chalk is on the side of the tred it is over inflated. If it is on the center and gone on the sides it is under inflated.
The width of the rim will come into play also.
Originally Posted by 07BLUEJK
That is just the MAX PSI for the tire. You should be in the 26 to 35 PSI range depending on the weight of your jeep. Do a chalk test.
