Question about ball joints
I just replaced the axles in my 2007. I was running Synergy after going through a couple sets of OEM style BJs (it took a couple years for the aftermarket to offer upgraded BJs). They had about 150K miles on them. Maybe more. Anyway, I did grease periodically. My mechanic who swapped the axles for me mentioned that the old BJs were worn out. I'm not sure if he measured or had just checked for movement. I had also never noticed any problem. And, even with the new Dynatrac BJs that came in the front axle, I can't really tell any improvement with the steering or other performance. It feels as good as it has always felt.
If the jeep is moderately or heavily modified and I was keeping it for a good while there is no doubt I'd buy Rare Parts. Most people scoff at their price, but BJs are an important steering component and are a leading cause of wobble issues, right behind track bar bolts and joints. I think a lot of folks view wobbles ad a nuisance rather than something that could easily cause a fatality in the wrong situation.
You may already know this, but just in case: The spec on the lower ball joint is less than .050" vertical play. Here's a pic of checking it with a dial indicator. A lot of people, including professionals and u-tubers, seem to expect near zero. My Jeep has a bit less that 0.040" and it drives just fine -- And that's 176K miles on stock units. I'd bet that if I asked a bunch of shops to check them, 8 out of 10 would say they were toast without ever taking a real measurement.
Knock on wood, I haven’t had a BJ issue since my nightmare rebuild in 2018, though the jeep seems to get less use these days and is more of a toy.
I replaced them with Rough Country. 2015 JKU 35 inch tires. Mostly a daily driver but lots of city driving. And the roads here are junk. I'm thinking about going with Terra Flex. They are definitely out of spec.
I'm running the Dynatrac HD ball joints and they have been great. And when they do wear out they are rebuildable. Highly recommend.
Dynatracs are super expensive, but they are beasts. I went through ball joints every few years until I just spent the money. Just make sure you do a touch of grease on the bottom ones every other oil change. Worth every penny, but was hard to press the submit button on the order!
