Question for anybody with Reid knuckles?
I was reading through the description on Jeepswag for these knuckles. It says they use the factory tie rod ends. But then in parenthesis it say its not compatible with the factory tie rod. is that the case? Why would they make it to use the factory tie rod ends, but not the factory tie rod? what does the factory tie rod interfere with? And what aftermarket tie rod is everybody using with these knuckles?
Thanks,
Thanks,
I was reading through the description on Jeepswag for these knuckles. It says they use the factory tie rod ends. But then in parenthesis it say its not compatible with the factory tie rod. is that the case? Why would they make it to use the factory tie rod ends, but not the factory tie rod? what does the factory tie rod interfere with? And what aftermarket tie rod is everybody using with these knuckles? Thanks,
Stock TR here in this pic
I'm using the stock one with my Reid knuckles part of my PR44 set up .... Now a shop installed it so I don't know what modifications he had to do to make it work..... If it wasn't -25 outside I'd go look lol
Its an error in their description. The Reid knuckles will work with a stock tie rod (although I don't understand why anyone will spend $500 on knuckles before replacing the tie rod) but not a stock drag link due to the flip.
I'm running one on mine. I went with the Reid's because that's what I bent on my 30 when it broke. Very nice, much beefier than stock.
People bend tie rods all the time I should probably upgrade since I've got about everything else on the axle. I also think reid brings it further up and out of harm. Underrated in my opinion
