Quick dumb question
Old Sep 22, 2010 | 08:07 AM
TN-MEDIC-14's Avatar
From: Christiana, Tennessee, United States, United States
Default Quick dumb question
Ok, I need new tires, new wheels are not in the budget, don't really want to run spacers. I have a TF leveling kit installed already, question is can I run 285/70r17 on stock wheels with out rubbing or would I have to drop down to a 265/70r17 to avoid rubbing?
I don't do much off roading any more (since wife is 5 months preg with our 3rd little girl) and when I do, I don't ever disco the sway bar.
P.s. I'm thinking nitto Terra grapplers if that matters
Thanks.
Tony
Old Sep 22, 2010 | 08:15 AM
Bustabizz's Avatar
Former Member
The 285 and the 265 are about the same width so that wouldn't matter much. And about an inch and a half taller.
Old Sep 22, 2010 | 08:20 AM
cppower's Avatar
You can run 33x11.5" tires and they will only rub on the swaybar at full lock.
And you can get rid of that rub with 4 washers and the Steering Stop fix.
http://project-jk.com/jeep-jk-write-...top-adjustment
( stock Rubicon Suspension components )
Old Sep 22, 2010 | 08:36 AM
Pluke the 2's Avatar
You sure?
Old Sep 22, 2010 | 09:17 AM
JKRockStomper's Avatar
Originally Posted by Pluke the 2
You sure?
yes, you just have to move the rear sway bar links to the inside of sway bar- top and bottom.
Old Sep 22, 2010 | 09:22 AM
mention that to the op and not me.
Old Sep 22, 2010 | 11:58 AM
So they will for sure , absolutely, with out a doubt will fit WITH OUT spacers, on a TF leveling kit... as long as the sway bar end links are moved to the Inside?
