Raingler Net Help
Alright. I spent two hundred dollars on these Raingler nets. They are definitely made extremely well and will probably last forever. And they look cool. Unfortunately, I can't figure out how to put them on because they didn't come with instructions.
I tried doing a search, but all I found was more people who complained about the same thing and no real help or decent photos. I also tried to PM a guy who said he had instructions but no answer.
I would appreciate it if someone could give me some help. Detailed photos would be a plus. Thanks.
google is your friend lol...not sure if you have 2 or 4dr but found these
]http://www.raingler.com/j2sn_side_netting_installation_2.htm]or send them an email here
"][COLOR="Silver"]http://www.offroadconcepts.net/[/COLOR
Good Luck
Good Luck
Last edited by Piginajeep; Jun 13, 2008 at 07:13 PM. Reason: dont post clickable links to non-sponsors..
They are a little different for the 2 door...I had trouble at first too. If you need help or pics, feel free to PM me.
here is when I first installed them:
Since I've actually removed the rear seat belts and they go on a bit better.
2 suggestions: To get the back even, attach one side but don't tighten all the way, maybe 50%. Then attach the other side. Then tighten both evenly.
For the side upper front mounting location: I couldn't find a good way around the rollbar so I threaded the strap through a small slot in the plastic door frame. It looks like it was meant to be there. Putting it through there will make the net level.
