Rattle/vibrating sound from gear shift
When accelerating and my engine/aftermarket exhaust creates a little vibration, I get a slight rattle noise from, best I can tell, gear shift. Seems I had read some time back that another member was getting a slight rattle noise from the gear shift area. It's not anything mechanical from what I can tell. When I grad the gear shift it tends to damped the noise.
It's got to be something down in the trim/housing at the gear shift. When accelerating and the mid range RPMs the sound occurs and I can simply put my hand on the gear shift and the rattle noise is dampened. I can't tell if there is a piece that may be down in there up against the shaft of the gear shift that is making this noise when there is the vibration from the engine RPM/exhaust or what. Gets very annoying though.
Any ideas?
Any ideas?
My 2013 has a four piece shift knob, the top silver part with the shift pattern, a chrome ring that goes around under that, then the black main body of the knob, and then another chrome ring around the bottom. Both of the chrome rings came loose at different times, and had to be glued back together. Both times it creates noises as you describe. If yours has this style knob, wrap your hand all the way around the knob and see if the noise goes away, I suspect it is that bottom chrome ring.
I also have what I believe you are describing.It is not always there but when it is there, it goes away when grabbing the gearshift.
The first time it happened it took a while to find the source of the noise.
Everything seems to work correctly except for the occasional noise.
KG6SLC aka Eugene
KG6SLC aka Eugene
KG6SLC aka Eugene
KG6SLC aka Eugene
