JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Rattle when acclerating (https://www.jk-forum.com/forums/modified-jk-tech-2/rattle-when-acclerating-258513/)
FrankieB Dec 27, 2012 10:03 PM
I've got a 4dr 2009 Sahara with 35s on a teraflex 2.5 coil and shock lift. I've noticed a rattle sound when accelerating hard to highway speed or climbing on local roads. Had one suggestion that it could be the wire for the speedometer.
Any ideas?
4wheels4life Dec 27, 2012 10:09 PM
Not sure if this is the same as what I had but check your heat shield that is stitch welded to your crossover exhaust pipe, the pipe that goes from passenger side to drivers side right behind the engine. Make sure one of the welds is not broken. Mine would rattle when I accelerated but stop when speed was constant.
Ryan0260 Dec 28, 2012 05:42 AM
Are you sure it is a rattle, or is it spark knock (pinging)? If it is a rattle, it is probably a heat shield
Jhouse93 Dec 28, 2012 06:02 AM
Ive often had rocks get lodged inbetween my exhaust crossover and my factory skid that would cause a rattle on acceleration...mabey something to look into, also heat shields as said before
jk.bushwacker Dec 28, 2012 06:44 AM
x2 - had the same issue, the welds go bad... i just clamped it. all better now :)
Jeff Loughlin Dec 28, 2012 07:07 AM
x3 - I put hose clamps at each of the weld points on that heat shield, and it quieted right down.
FYI, you might not see a broken weld when you look for it - mine looked fine and didn't feel loose, but I tried the hose clamp fix anyway at a friend's suggestion, and it worked. Must have been just a tiny crack in one of the welds, but big enough to allow it to vibrate under acceleration.
JKingAround Dec 28, 2012 07:16 AM
Check all your heat shields including manifold, the ones on the floorboards under the cab and the ones by the motor mounts. I had one loosen under the cab and one bend on the motor mount that both made a noise until I lost the one under the floorboards and bent the one on the motor mount out of the way.
FrankieB Dec 28, 2012 09:37 AM
Thanks all, I'm going to check on those suggestions this afternoon and will update. Thanks
MangoWilly Dec 28, 2012 12:35 PM
I just had a shop install my skidrow engine and tranny skid while also installing a sleeve and gusset kit. Since they had to bend a bracket while fidgeting with the exhaust, is it possible they broke the stitch welds on the heat manifold like you guys are talking about? I'm all the sudden hsaring a rattling while I am reversing or while I am accelerating at a light... it doesn't happen all the time, but it has been happening since the night of install. Had them mess with the exhaust today to get it to stop but still seems to be making noise. What should I look for exactly?
09jaykay Dec 28, 2012 03:26 PM
It's most Likely sparknock, try upgrading to a tank of 89 octane and see if it goes a way.
© 2026 MH Sub I, LLC dba Internet Brands
