RC 2.5 Coils/ 2.2 Shock Install
I did this lift install last night in about 4 hours and that included the test drives to center the wheel. Fairly simple and easy. Drove the Rubi to work today and it rides about the same as the stock setup. The stock rear springs w/o the stock gas shocks are a joke. Better hope those stock rubi shocks hold up a while if you dont do any mods as the rear stock coils are useless for hauling any thing more than groceries. Now for rims/tires-too many choices and too little time.:thumbsup:
I'm looking at getting this same lift. Was it pretty straight forward without any snags? Where did you get yours from?
It was staight forward. Just jack it up high enough so when you let the axles down the new coils go in with no hitches. I purchased it right from RC directly while they had a sale on. I talked to Ben at RC and he was most helpful. Watch on the rear to take off the breather hose and unclip the ABS wires while you are working. It did take me a little longer to install but I neverseized everything as it went back together. I just have to check the caster now but that is recommended with any lift. Rides good-almost same as stock and will probably have a little more capacity-although RC does not make that claim.
Congrats. Did you get any pics? Install, before/after, etc?
Lift
I am getting ready to buy that set up. Question I thought re centering the wheel was not necessary?
Always recenter the steering wheel after a lift. Plus it only takes 3-4 mins and is really easy.
Awesome advice :thumbsup: I will be doing this lift on my Sahara Sat Morning by myself and throwing on 35's. I will then see if I need any other lift like another inch BL or if I will just be fine with the 2.5 Coil. I will be running 17x8 Procomp wheels w 4.5 BS and 35x12.50 Xtreme MT tires. I will take some pics before and after...
Originally Posted by Jeepnatvguy
(Post 968106)
(Post 968106)
35 or bust!
