Rear Sway Bar Links Rubbing Wheels
Hey. I haven't been on here in forever but now I need help. I have a 2007 Rubi with a 4" lift. The lift was originally a rough country lift but I used Currie's arms. (All 8) I used adjustable sway bar links to level the arms versus them being angled down but I don't remember the brand. I bought and installed BFG KM2 35X12 tires on Mickey Thompson Wheels.
I have saved my factory wheels and tires and now need to install them on my jeep due to wear on the BFG's and current financial situation. When I do this, the rear sway bar adjustable links rub the inside of the factory wheels. ]
Do you all know if there is a manufacturer of sway bar links that will allow the running of the factory wheels while keeping[ the rear sway bar level?
I guess I could always just use the original factory ones (yes I saved them also) to prevent rubbing.
Thanks in advance. I'll check back for answers in a while.
Bodo
I see in my stats that the links are Northridge 4x4 adjustable sway bar links?
Bodo
Agreed, this mainly sounds like a wheel issue and not having proper back spacing. Running wheel spacers would be a fix, but would kinda suck since it sounds like you just bought those wheels. Other alternative is inboarding the links like suggested above. If you do that, be very careful you clear your hard brake line otherwise you could flex up, grab the line, and pull it down sharply. The last thing might be to buy different sway bar links that are more narrow. Not sure which ones you have, but look at Rock Krawler's or another model that might offer a slimmer solution.
tbh, all of these "solutions" suck vs. just having properly back spaced wheels to start with.
Seems like I tried to mount the links inboard and that wouldn't work. I bought the wheels and tires years ago. I only have 55000 miles on this Rubi but the tires are getting worn. I need to replace them and was hoping to use the original tires and wheels since I have stored them and they are practically brand new. (Yeah I know they are gonna look funny with a 4" lift but medical bills are taking precedence now.)
Any manufacturers got any suggestions?
Thanks y'all.
Barry
Thanks y'all.
Barry
Thanks y'all.
Barry
Thanks y'all.
Barry
Thanks for the replies. The adjustable links will not install on the inside due to interference from bolt heads. I could go back to the factory sway bar links but that will tilt the rear swayer down. Would this be a dangerous thing? Seems like I ran it this way for a while before installing the adjustable links. Memory may be slipping though.
If the factory sway bar lengths were just way to short, yet another option is to make your own new ones. I made my own rear end links out of 4 rod ends off ebay for $20 shipped free, $6 stick of 1/2" all thread, and small bit of grade 8 bolts/nuts/washers from hardware store.
I recall free shipping on the ones I bought, but example -
ECON 1/2 x 1/2-20 FEMALE RH ROD ENDS HEIM JOINTS HEIMS | eBay
Former Vendor
What is your wheel backspacing? Just run a spacer and make it easy on yourself. Nothing wrong with a wheel spacer as long as it's a quality brand and properly installed.
OP is strapped for cash, has to go back to factory wheels due to budget for the time being. Spacers are best option all things considered, but still trying to find a cheaper solution....that is why asking about the factory links again.
