Rear Trac Lok and regearing?
I have a 16 JK 2 door sport s, I'm regearing from 3.21s up to 4.56s. I need a new low ratio carrier for the dana 30 front. Will the Trac Lok be affected in the rear with the new regear install? Dana 44 in the rear and a carrier replacement isn't needed.
I just wanted to know will the rear trac Lok become an open dif after regearing?
But the factory limited uses clutches, which eventually wear out, becoming just an open diff. How long that takes will depend on your usage. Maybe never, maybe after only a few years.
If you are concerned about improving your jeeps traction, now might be the time to buy something better. Especially for the front, since you are already buying a new open carrier.
Because of the regear? No.
I am not suggesting the following is mandatory, but it may be helpful to consider.
The clutch based LSD's are fairly inexpensive to manufacture but if you can afford it I am a huge fan of the TrueTrac and other Helical LSDs. Not only do they work instantaneously they will actually bias the torque.
In a Clutch based LSD (/Posi/etc..) it is typical to get about a 30% lockup when the plates are new. With TrueTrac you get 350% of the torque to one side, and with the BLD system in the JK this works in almost all conditions. There is also the advantage where a TruTrac will put slightly less stress on the drivetrain and reduce the chances of breaking parts.
To put the above numbers in context, as they are different units measure, here is some very approximate math.
100 ft/lbs of torque from the driveshaft would result in the following amount on the tire with traction (ignoring gearing/losses etc...)
Clutch based = 30 ft/lbs
TrueTrac = ~78 ft/lbs
If you are into obstacles and/or rock crawling lockers may still be your best bet, but I like having an LSD which is working all the time I am off road or in the snow. Tastes, use cases, driving styles, and opinions differ but it is a lot less maintenance to swap in a helical when regearing if you like a LSD.
