JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Rear Track Bar??? (https://www.jk-forum.com/forums/modified-jk-tech-2/rear-track-bar-258851/)
Jersey_Devil Dec 30, 2012 08:39 PM
OK so how come my buddies 2.5" Skyjacker sport lift came with a rear track bar relocate bracket but my 4" Skyjacker lift didn't? Should I be buying one?
I have ZERO problems (knock wood) and I go wheeling all the time.
k0260 Dec 30, 2012 08:47 PM
I'm using TF's HD bracket primarily for piece of mind being that the front and rear axle end mounts are prone to breaking. If you'd like better on road manners, both the front and rear brackets are nice investments I think, to raise your roll center giving you a lot better handling and less body roll. Other than knowing I'm safe from breakage, I noticed a big improvement in handling.:dontknow2:
quick edit:
I'm using Synergy's front bracket, both Synergy front and TF's HD rear raise the Jeep's roll center by 3". Huge improvement for me with 3.5" lift. Less wondering feeling, more controlled on turns especially.
Jersey_Devil Dec 30, 2012 09:36 PM
OK.... Seeing as I'm stock in that dept I was just wondering..... Thanks! I knew it was to center the axles but wasn't sure if I needed it since my kit didn't come with it.
courtsm3 Dec 30, 2012 09:41 PM
i also did the teraflex HD rear bracket and did a front pro comp adjustable front track bar. jeep drives nicer and doesn't pull to either side after bumpy pavement. off road i noticed no difference, its the street manors that improve
aldaman Dec 30, 2012 11:31 PM
It depends. Is the reason why your 4" lift didn't come with a relocation bracket is because it came with an adjustable track bar instead? If so then you should be good to go. If not then you would have to measure your axle and see if there is any difference between your driver and passenger tire. Most likely with that much lift, it will be off. Getting an adjustable track bar will help recenter your axle.
When I installed my 2.5" RK lift it came with a rear track bar relocation bracket to center my axle. But I also added a 1/2" TF rear spacer, that pushed my axle closer to the driver side. I then noticed my passenger JKS sway bar link was rubbing my tire, so I purchased a TF rear track bar to recenter my axle. Problem solved...
KCTW Dec 31, 2012 04:14 AM
Your lift should have come with a track bar relocation bracket for the front and rear, as well as a brace that runs over to the diff cover for the front and rear.
Edit, I would get one of these, and run your stock track bar.
Poly Performance JEEP/TRUCK & BUGGY :: Suspension :: Suspension & Lift Kits :: Jeep Suspension Systems :: 2007-Current Jeep JK Wrangler Suspension Systems :: Synergy Suspension :: Synergy Suspension Jeep JK 3"+ Bolt-on Rear Track Bar Bracket - 4X4 Of
Jersey_Devil Dec 31, 2012 05:13 AM
Poly Performance JEEP/TRUCK & BUGGY*::*Suspension*::*Suspension & Lift Kits*::*Jeep Suspension Systems*::*2007-Current Jeep JK Wrangler Suspension Systems*::*Synergy Suspension*::*Synergy Suspension Jeep JK 3"+ Bolt-on Rear Track Bar Bracket - 4X4 Of
Well the lift it got was just 4 coils, 4 shocks, dual stabilizer setup..... Nothing else came. My buddies kit only came with the rear relocation..... Nothing for the front.
Well I'm gonna call skyjacker today and ask..... If their open.
Jersey_Devil Dec 31, 2012 05:50 AM
Just got off the phone with Skyjacker and the guy I spoke to told me that I DONT need it with my kit..... But he also sounded a lil confused at the same time.......
KCTW Dec 31, 2012 06:48 AM
You don't by chance know the part number for this lift do ya ? I was just on Skyjackers website and didn't see a 4" kit that was just springs and shocks. All 4" lifts they have listed come with track bar brackets.
I'm not trying to bust your chops, I'm just trying to help.
Is it either of these ? Its the only two I could find that came with shocks.
Item #JK401KHX-R / Skyjacker Suspensions
Item #JK40BPH-R / Skyjacker Suspensions
Sgt Mack Dec 31, 2012 07:05 AM
Get a bracket! In 07 I ran a 2" skyjacker lift, my trackbar snapped right off while driving down the freeway!! Stock tabs aren't thick or really welded on there. Get something that welds on or boils around the axle!
© 2026 MH Sub I, LLC dba Internet Brands
