Rear Track Bar hitting coils? How to fix this?
Yeah I see that. I’ll measure tomorrow. A buddy of mine said my springs looked too bowed as well and should check my wedges to see if I can’t straighten them out or buy a new adjustable track bar.
The bowed springs are a byproduct of extending the arms and pushing the axle back (the spring perch on the axle no longer lines up with the mount under the tub.) This is a normal thing. The best solution is to cut off the axle side perch and re orientate with new weld on ones or an adjustable ones which isn't a super cheap option so most of us live with it. If you can weld, it's a good cheap project.
I had the same issue on my 2013 10A Rubicon just after putting on my 3.5" lift. I took it to a place that specializes in Jeeps. He removed the spring perches, reoriented them to the correct position for the lift then welded them back on. Just as stated in the previous post.
Haven't had a problem since........at least with the suspension that is.
KG6SLC aka Eugene
KG6SLC aka Eugene
Simplest fix is degree wedge rear lower spring seats by Synergy or Rock Krawler. These will stand the spring up straight and thus clear the track bar. I've run these for 10 years and nearly 80k miles, no issues. They add about 1/2" lift.
https://www.northridge4x4.com/part/c...on-wedges-rear
