Recommended tire pressure?
Pressures really depend on what load rating you are running. If you have the C rated then I would suggest starting at 30 and looking for a crown in the center of the tread. If running D's or E's, start at 25 PSI. You will notice a ride difference at different PSI's but don't adjust the pressure purely based on ride quality. This can mask issues with your suspension and expose you to tire damage and possible safety concerns. What you want is an optimum pressure that gives you a flat contact patch on the road. However, it also has to be high enough to keep the tires on the wheels and prevent distortion at high speeds. This will give you the best ride quality and the best tire wear and protect that expensive rubber investment you just made.
