Removing Sound Deadening Goop
I'm going to bed line my tub. Just had a question about removing the sound deadening goop. I will, obviously, remove the goop from the bottom of the tub.
But, I'm wondering about along the junction of the bottom and the sides
and along the upper part of the side of the tub
Do you think this should also be removed? Is this the same material? Perhaps this is covering a seam rather than just serving as a sound deadening application.
I'd leave the seam sealer alone on the edges. I know you're looking for a smooth look but that is not a place I'd remove the goop.
For the floorboards- if you get it good and wet, it'll come up with a putty knife.
Just got finished reading this thread... Mark9998 said he used a wire wheel on a drill (along with keeping the goop wet) to remove it. Said it worked out nicely and had a few pics of it as well.
https://www.jk-forum.com/forums/jk-w...r-blue-157693/
The goop on mine was just a flat sheet of it. Not the drizzle looking kind. Mines a 15, so maybe they changed the design? For what it's worth I used a heat gun from harbor freight for like 9 bucks on sale. It came up very easy with putty knife after being heated.
