Replacement Gas Tank Skid
Poly Performance sells a gas tank skid plate that replaces the factory but most others do require the factory one to remain in place since it holds the tank up.
In my case, I ran the factory one for 10 years and its at the point where I am losing volume in the tank so I searched for a while and found one in decent shape on car-part. I didnt want to pay 400+ that the OEM unit costs
Yep, same here. When I "fill up" at the gas station, the needle on my gauge is 2 ticks less than full. I'm more worried bout my tank at the moment. I can visibly see where it's crushed up. Wish I had free time to drop the "skid" sooner to relieve the pressure.
@resharp001 You'd think no one in their right mind would do so. I seem to have to do so and wanted some input before I go spending nearly $1000 on this project.
The input I would like is should I just band-aid it with a Rubicon Express skid? Hell the RE skid may not even work since the skid plate mount tore out completely. There's no way I can have someone weld in something to provide the mount bolt support. If I cheap it an try to use the RE plate, is it okay to run the JK without the factory transfer case plate? You know how much of nance I can be Resharp when it comes to off-roading!
I'm not sure how much longer I will keep this JK. I keep waffling on selling it to get something else, but I am happy with not owing any money on such a well-running machine. It lacks a lot of functionality for me and my wife in regards to going camping. I found a Clayton off-road replacement skid for about $560. It looks like I would need to replace the transfer case skid too with Clayton to the tune of an extra $400, or just skip transfer case skid altogether. Me being me, if I drop the fuel tank might as well change the whole fuel pump assembly too.
Skid plate arm
Factory skid plate attachment
Pennsylvania road yuck
Pennsylvania again
-facepalm-
I had a similar issue with my factory gas tank skid rusting, and I understand your desire to find a replacement that not only addresses the rust but also saves weight. In my experience, I found a great solution with the aluminum gas tank skid from A Chick and a Windshield in Colorado Springs. Their skid not only provided the durability I needed but also significantly reduced the weight compared to the factory skid. You can check out their website<!--td {border: 1px solid #cccccc;}br {mso-data-placement:same-cell;}-->https://achickandawindshield.com/ for more information and explore their range of skid options. I highly recommend their products for a reliable and lightweight solution.
I just spray the hell out of mine occassionally on top of the skid plate tank holder. Oil or Rust Check in aerosol can sits in there and protects. Mine is now 14 years old and Calagary is not as salty as the east but I think I need to replace this Jeep in the next 3-4 years. Then I need to do another conversion this time a 6.2LT/10 speed auto.
Pity someone did not pull a mould off the factory plate and make a glass product.
I have a similar issue with my gas tank skid plate.
One of the support straps that's part of the skid plate is nearly gone.
I had it checked out and it's "ok" for now, but I was told to plan on replacing it soon.
I found new ones for about $400, but I might give welding it a shot since I'm trying to teach myself to stick weld and I have a decent ac/dc welder...
But for now, I'm going to enjoy the jeep this summer, and plan on doing something about it this winter.
