Spray On Bedliner for Factory Fender Flares?
Has Anyone done this? ANy tips/suggestions? I am sure i'll need to strip all the armorall/black magic off first!
Are these easily removed/reinstalled?
Thanks
B
Thanks
B
I did this with my OEM fenders. Used Simple Green degreaser to clean them then sprayed them with Dupli Color Truck Bed Coating (blue can). They lasted at least the 3 years I had them one (moved to different fenders) when I gave them away they still looked great.
Great. Thanks for info/Simple Green Suggestion..
It looks more complicated than it actually is. Just some bolts and a bunch of plastic clips. Wouldn't be a bad idea to have extra clips on hand for the re-install.
clipsandfasteners.com
A20887 - box of 15 - $9.02
A11146 - box of 25 - $3.18
Good idea Thanks.. That was one of my concerns was clips breaking!
Definitely get extra clips. you can buy them in a kit. They will break no matter how careful you are.
I did this with the bushmaster extended pocket flares, but for the cost of the bushmasters I should have kept factory flares. Used Raptor Liner. Degreased flares, cleaned with alcohol, plus also used u-pol adhesion promoter. The liner is holding up great. Just be sure to let it cure for a few days before reinstall to ensure that it keeps a good adhesion.
Found the fasteners on Amazon as well. about same price but free prime shipping..
