Rhino Liner
Has anyone taken the carpet out of their JK yet? I used to keep it out of my 97 TJ about 3/4 of the time (it never went in the same after I removed it) and wonder if it removes easily in the JK. If I do get it out I was thinking about getting a spray-in liner like Rhino or Line-x. Does anyone have experience with this? Does it provide sound/heat dampininng? Is it too heavy? Does it look good? Is it worth the cost to protect the interior metal (my TJ floorboard paint wore off from the carpet rubbing).
If spray-in liners are not good I was thinking about Husky Liners v/s factory mats... has anyone bought the ones for the JK? Do they fit well? |
Jeeping and carpet do not mix
I've been in jeeps since 1983 and will assure you that carpet and jeeping do not mix, the result being RUST...yesterday I went to my dealer (I have a Rubicon Unlimited on order) and specifically looked at the carpet and got under to see where the drain holes were located...it appears the carpet will be a problem to remove and replace, in my opinion it is best removed and left out, I've used chipguard coating in all my others...I found six drains (there may be more) about 2.5"x1" with plugs similar to what Jeep has always used...several appeared not to be located at low points in the floor...if you ford 30" of water hope it will drain fast...it appears someone at Jeep was aware of the problem but trying to mix production for 2 wheelers and off-roaders causes a bind...GET RID OF THE CARPET!!!
I agree with the pulling it out comment, but I tend to do that when I do soak it. A little time hanging outside & it's dry & ready to go back in. I like having carpet when I'm daily driving my Jeep. This stuff is so sculpted it's gonna be hard to do though.
I think the carpet is bonded to the little door on the floor too. Maybe a diamond plate one will show up for the aftermarket. |
Personally, I like keeping the factory carpet in especially since it has the heat shielding attached to it in key spots. Granted, I live in SoCal and we don't get the kind of rain, mudding or water crossings that a lot of you other guys see. Mostly desert and dry sharp rocks out here. Having said that, I have sprayed in my own Herculiner in my CJ and like the results a lot. If this were something you were seriously considering, I would highly recommend it. Just make sure to apply the UV top coat to it or else it will fade. As far as sound dampening or heat absorbtion goes, it is only minimal at best and certainly nothing as good as the carpeting.
Bed liner
If you do remove the carpet and spray the floor use the good stuff. Spend the extra money and avoid the auto store brands they all suck. Line-X is better looking but rhino is thicker and more durable.:yup:
I want to rhino liner my bumpers and mirror covers.
Originally Posted by clifford901
(Post 2373)
http://www.4x4xplor.com/images/herculiner/herc02.jpg http://www.4x4xplor.com/images/herculiner/herc01.jpg The trick is in the prep work and in how you apply it. If you roll it on, it'll look like crap. :) |
Originally Posted by Massvet
(Post 2579)
thanks for the heads up, I would have done this too..!!!1
And to think my girlfriend made me promise not to join any kind of forum after getting my JK because of my last auto addiction. I would have never known! |
(Post 2587)
