Riddler vs Rugged Ridge Diff covers??
Old Jan 12, 2011 | 05:59 PM
Northridge4x4's Avatar
Sponsoring Vendor
I am looking to up grade the covers as well, don't see Drain hole on the Riddler. Am I missing something ????
They dont have a drain plug but they do have a Fill plug.
David
Old Jan 12, 2011 | 06:08 PM
JKRINGO's Avatar
After checking the Write-up section found the drain plug is in the housing. (my bad)
Old Jan 12, 2011 | 06:28 PM
azsandrider's Avatar
That is a good deal!
Got to order me the set...
Is it the Riddler's that people had problems with the hardware? Should get better bolts to use when I install them?
Old Jan 12, 2011 | 09:41 PM
Red Dog's Avatar
Riddler and Poison spider are the same. I have the PS and they are great. I like them because they are smooth so they don’t get caught on things and thick so they can take a hit.
Old Jan 13, 2011 | 02:20 AM
Mark Doiron's Avatar
IIRC, some folks had problems a while back when torquing down the bolts with Lubelockers. I have that combo (Riddlers and Lubelockers) and have not had a problem.
Old Jan 13, 2011 | 02:34 AM
Rhino64's Avatar
Originally Posted by Fitba101
Ok guys, I am planning to get some diff covers for my 08 unlimited and was wondering which you guys would recommend. The 2 I'm looking at are the Riddles or the Rugged Ridge ones. They're pretty close in price, so that isn't an issue. Here are some links if you guys are interested.
trailduty.com/product_info.php?products_id=618
http://www.4wd.com/productdetails.aspx?partID=4414
Also, has anyone else installed either of these? Any problems?? Things you love, hate...
Use you're stock cover up front and guard it with this, you only lose a small amount of ground clearance. Thats what I did the rock slider is close to bullet proof. It will move rocks.
Old Jan 13, 2011 | 04:30 AM
R n Y's Avatar
I wouldn't buy any RR product that is cast.. Poor quality control from over sea's.
My .02
Old Jan 13, 2011 | 04:46 AM
4WHLN's Avatar
x2. same setup and havent had any problems.
Old Jan 13, 2011 | 05:06 AM
Matador's Avatar
Here's what i found doing my research
This is someone that had a Riddler on their JK.
Name:	riddler damages.jpg
I quote "thats Royal purple flowing out the bottom, all the bolts but 2 sheared off, and the bottom of the cover bent out of shape! "
Yes, Riddler has a lifetime warranty....
I am not knocking the product as I have never used it......but I guess it's something to think about.
I went with ARB's from Northridge!
Old Jan 13, 2011 | 07:15 AM
Sponsoring Vendor
You hit anything hard enough and something like this could happen imagine if that person still had a stock cover.
David
