Rims
Old May 6, 2007 | 08:45 PM
joeyh6's Avatar
Default Rims
Was wondering if anyone could tell me what backspacing 15" rims will fit on a JK
Old May 7, 2007 | 05:02 AM
armycop's Avatar
It depends on the width of the tire and rim you want to use. Plus 15 is tight, maybe 16 will be easier for clearance issues. For a 15x8 5 inches or less backspace would look good, for wider rims you would want about 4-4.5 inches of backspace.
Old May 7, 2007 | 05:06 AM
BLKRUBI's Avatar
From reading threads on here (I'm running 18's so I have no direct experience).....the 15" Crager Soft 8's will fit with 4" of B.S. only, any other Backspacing on those wheels will not fit. Hope that helps.
Old May 7, 2007 | 07:54 PM
1JK's*'s Avatar
Default 5" backspacing won't work
Take it from someone who learned the hard way. At least with the Cragar 15X8's, 5" of backspace won't work . The centerline drop on the rim hits the brake caliper. You need a 15" rim with 4-4.5" of backspace and no more. But that is my limited experience talking. Good luck.
