ring gear wear pattern
Old Mar 15, 2010 | 07:05 PM
ChunksInMud's Avatar
I actually had a similar problem, ended up replacing the gears. I had run about 1800 miles before it came out. Took it to my shop, they replaced the gears and said it was a material defect.
What gears are you running?
Old Mar 16, 2010 | 09:03 AM
rocknredrubi's Avatar
Superior 5:13s
Old Mar 16, 2010 | 09:44 AM
RedneckJeep's Avatar
Look at this picture. If the red circled area is NOT a camera flash, but it the actual wear pattern, then the pinion depth is a tad too shallow. It should be right in the center of the ring gear tooth, and as you can see, it is not. Whether this is causing your noise though, I have no idea since I cannot hear it.
Old Mar 16, 2010 | 10:20 AM
BlackNorthernJK's Avatar
if you're really concerned with how the pattern is meshing, I highly suggest you get some gear marking paint and paint it on those gears, then run a proper pattern for us to see...with the axle fully assembled like that it will be super easy to run an accurate pattern as you require about 50 ft/lbs of drag on the carrier to get a nice pattern, easy done by lightly applying the brakes while spinning the drive shaft back and forth through the paint a couple times. Just head to your local gear or driveline shop, they should have all the paint you want
