river raider hi-lift bracket install
ok guys this is my first write up so i hope its a good one. i have been looking for a way to mount my hi-lift and did'nt like the hood mount or the tailgate door hinge mount either so @ the all brands jeep show in york , PA i saw this @ the river raider tent installed on a vehicle and thought it was the best thing out there so here goes...
first thing is locate the factory holes on the rear of the rollbar driver side http://i292.photobucket.com/albums/m...k/DSCN0552.jpg passenger side http://i292.photobucket.com/albums/m...k/DSCN0553.jpg now using the supplied tap and a adjustable wrench http://i292.photobucket.com/albums/m...k/DSCN0555.jpg insert the tip into the hole and turn clockwise if it gets stuck or hard to turn back off a turn then continue http://i292.photobucket.com/albums/m...k/DSCN0556.jpg repeat on the other side http://i292.photobucket.com/albums/m...k/DSCN0557.jpg now simply use the supplied 3/4" bolts and washers attach the jack mounts http://i292.photobucket.com/albums/m...k/DSCN0558.jpg http://i292.photobucket.com/albums/m...k/DSCN0559.jpg http://i292.photobucket.com/albums/m...k/DSCN0549.jpg liquid thread lock is recommended on the 3/4" bolts. remove the factory bolt from thehead of your lift and replace it with the supplied 2" bolt which will hold your hi-lift to the jack mount using the supplied washers and wing nut http://i292.photobucket.com/albums/m...k/DSCN0560.jpg this is the finished product. http://i292.photobucket.com/albums/m...k/DSCN0569.jpg http://i292.photobucket.com/albums/m...k/DSCN0547.jpg ..now i must tell you that there are two holes directly above the two that river raider wants you to use and this was done strictly for my set up on my jk being that i do not use the factory softop which has been replaced by my bikini, duster deck cover and the windjammer so if you go ahead and install it this way using the upper holes instead of the manufacturers setup then you do so at your own risk.... |
I dont see any Pics....:redx:
i messed this one up im trying to get the pics from my photobucket, sorry guys
I just had to!
:worthless:
Originally Posted by judesign
(Post 607586)
Are you still trying, cause i wanna see your write up.
I just picked up my RR brackets this past weekend at the PA Jeep show. I'll probably install mine tomorrow. I'll take some picks and post up...that is if the jack will clear my Mopar trunk. ...it's gonna be close.
Originally Posted by roguejk
(Post 607553)
p.s. maybe move this to the WRITE UP section :dontknow2: |
